Parameter variation / Adaptive parameter
02:47 AM
Hi Experts,
I would like to vary a parameter within the sketch environment where each polygon's circumscribed radius varies as the distance from a point increases . i am able to define parameters but i an unable to vary each instance to a different value, as in this case its radius/diameter. How am i to achieve this within fusion?
i have attached here images of what would like to achieve. Fusion: Polygon with rectangular array, uniform value for each controlled by a user parameter.
Desired Result: i would like to vary the value of the radius parameter of each polygon with respect to its distance from the cross point.
