parameter trick to hide/disable objects
nClarke0101
nClarke0101
Is there any way to use a on/off toggle in parameter to hide/disable a object/component?
jhackney1972
I do not think this is possible in Fusion 360.  This feature is offered in more advanced Autodesk CAD packages such as Inventor.
John Hackney, Retired
nClarke0101
is there a option to move the component out of a area and only show components that are in a selected area with a feature or something?
I did try and play around with Inventor but i dont really like that every component needs to be its own file, plus fusion sketch seems better / easier with the way it works / looks, unless that can be changed to look like fusion?
jhackney1972
The Screencast will show you the use of the Isolate/Unisolate command which I think is what you want.
By the way, do not use the Forum Quick Reply icon when you post, you are posting to your self.  Use the Reply icon on the Forum post of the person you are addressing.
nClarke0101
Thanks for reply, not really what im trying to do because i would like to control it with parameters
jhackney1972
You will not be able to do it with parameters so I would get use to the tools available.
etfrench
Investigate the API.
ETFrench
