Parameter's expression edit failed.
Hi all,
I was making a file were I could use the Parameters formula table to open or close the jaws in the assembly file of the chuck. However, after making the formulas (they work), when I type the Name of the expression on the Slide Rest (value were the component rest in the slide joint) it says this and the expression is in red.
"Parameter's expression edit failed.
Invalid string 'RestJaws' in the expression. Please provide a valid expression."
Does anyone know what could be the solution for this problem.
