Parameter ideas required
Ryan_Fab
Ryan_Fab
I am looking for some help with parametric design.
I have a large rectangle, "A", which dimensions are driven by parameters.
I then draw another rectangle, "B", the size of this is changeable and will be the result of a sum/method I'm yet to find!?
I create a third rectangle, "C", which is "B" offset by 2mm. This relationship is constant.
I then create a coincident constraint between "A" and "C" at their bottom left corners.
What I am trying, and failing, to come up with is a sum or a parameter driven way to make rectangle "C" array and fit wholly inside of "A" a pre-determined a number of times.
Please note that "A" can always change and be to decimals as too will the number of zones in the x and y axis.
Ive read this a few times and Im not sure how clear it is! so here's some examples of what im looking to achieve
1. Variables.                             A = 200 x 200                     Zones in X 2, zones in Y 2
2. Variables.                                A = 200 x 200                     Zones in X 4, zones in Y 4.
3. Variables.                    A = 134 x 306                    Zones in X 3, zones in Y 2
Hopefully someone understands this and is able to help!
cheers
TheCADWhisperer
@Ryan_Fab
Why are you creating sketch pattern rather than feature pattern?
What are you attempting to model - do you have a picture of something similar that already exists in the real world?
Ryan_Fab
Hello, thanks for taking the time to look.
sketch array, feature pattern, Ive been playing with both. But my issue is getting them to work with parameters
I didnt really have anything to send so I've just knocked up a quick model. The attached is what I'm looking to achieve, its a very simple thing just with endless options. The overall shape can change size and the number of extruded pockets can change, the quantity of these in the x and y axis will not necessarily be equal . What must remain constant is the 4mm wall thickness around them
Im hoping that when Im given a change of spec I can change a few parameters and fusion will do the work for me.
g-andresen
simply take a look at this design
(view in My Videos)
günther
Ryan_Fab
That is fantastic, exactly what I want to do.
thank you so much
g-andresen
Here is an extension for pluggable dividers.
(view in My Videos)
günther
