Parameter containing ratio not evaluated correctly
patrik-web
patrik-web
I'm doing some arc length calculations and am running into problems:
I have two parameters: "length = 1"" and "radius = 2"".
Now I want to calculate a third parameter that is the remainder of a 90-degree angle after this arc. I add a new parameter
"remainder", set the unit to angle/deg and enter the expression "90 deg - 1 rad * (length / radius)". The answer should be 90 deg - 1 rad * 0.5 or about 90 - 57/2 = 58.5 degrees. However, when I hit enter in the expression window, it is replaced by "90 deg - 1 rad mm / mm", or 32.7 degrees. The factor 1/2 from the ratio of the two lengths is missing.
I was under the impression that the expression calculator should be able to handle ratios resulting in unitless numbers. Is that not the case, or is this a bug in the code? It's in any case pretty bad that it does not give an error but just silently substitutes an incorrect result.
lucasproko
Hey @patrik-web,
I'm sorry you're running into this issue. I was just able to recreate the situation on my computer using the same steps you described. I'm guessing this is a bug in our system, but I will follow up with a few of my colleagues to see what exactly causes this behavior. In the meantime, there is a work around if you create an additional parameter to hold the unitless value, and then use that parameter in your calculation as you see below.
Hopefully that helps a little bit, but thank you for pointing this out!
Lucas Prokopiak
Fusion 360 Product Manager (Sketch/Model)
patrik-web
Ok, that's a decent workaround... as long as you notice the result being wrong in the first place. 😉
