Parabola?
9 REPLIES 9
Message 1 of 10
6745 Views, 9 Replies
Parabola?
Is there no way to draw a parabola in Fusion 360?
Parabola?
9 REPLIES 9
Message 2 of 10
AndrewSears
AndrewSears
The current build of Fusion360 does not have the ability to "draw" an equation controlled parabola. Here are 2 suggestions.
1) Try modeling a cone and inserting a plane if you know the angle and starting position WRT the base of the cone.  You can then project the intersecting edges of the cone into a sketch created on the plane and get a parabola.
2) If you do not need the parabola to be precise (you are just going for close enough) you could use a spline curve with symmetry.
Give that a try and see if this gets you to your solution.  If you are having problems with this let me know and I will help you work on it.  Might need to break out that geometry or calculus book.  🙂
Andy
Andy
Message 3 of 10
rishivadher
rishivadher
hi
for complex geometric funcions I usually use the Maple, but this has also plots SVG (http://www.padowan.dk), and plot the SVG can be imported to Fusion 360
hi
Message 4 of 10
Z.P.
in reply to: AndrewSears
Z.P.
I am going to take a screenshot of a parabola in desmos and then trace the screenshot with a bunch of little curves... wish me luck
Message 5 of 10
etfrench
in reply to: Z.P.
etfrench
Perhaps it would be easier to use the built-in function Conic Curve Smiley Surprised
ETFrench
ETFrench
Message 6 of 10
in reply to: Z.P.
i  have just created a parabola with the control point spline function. its seems to be exactly what i needed.
I hope the image shows the relations clear enough, since i dont know how to explain it clearly.Zaklamp parabool forum.PNG
Message 7 of 10
etfrench
etfrench
It's a spline, but is it also a parabola?
See this site for another way to create a parabola.
ETFrench
ETFrench
Message 8 of 10
in reply to: etfrench
i've made a screenshot of a parabola that i made in geogebra, and used that to trace it and it seems to be exactly following that function.      (y= sqrt(18.906x)   A(9.543,0)  )parabool.PNG
Message 9 of 10
chromation
chromation
There are two ways in Fusion 360: Conic Curve with rho=0.5, and Control Point Spline. Locate three points before drawing the curve:
- the two endpoints of the parabola
- the point where the tangents to the parabola endpoints intersect
For more detail, please see my reply to a similar question:
https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-represent-a-quadratic-bezier-curve-...
Message 10 of 10
drew.regner
drew.regner
Another way if you know the Parabola function you are using make a table and solve for the values and put those points in then connect it with a spline, mirror it about the vertex and it should make the parabola pretty nice.  Just like we did back in Algebra 2 in High School.
