Message 1 of 10
I made a series of symmetrical sketch curves that overlap, but when I highlight or click on them, the selection is not symmetrical i.e. I cannot selecton smaller sections that I need to perform loft/extrusions later on in my timeline.
I did a screenprint to show what I mean - the highlighted area is not symmetrical when it should be.
This is what I am trying to achieve below - I need to Loft on the right side of the sketch too, but the above issue means I cannot select the areas I need.
You can see that when I try the same on the right side of the sketch with a new loft, I cannot select the same small area at each level. Any thoughts please on how to resolve this?
