Message 1 of 11
Hi, I am trying to apply the Scale tool to a body (the body is in a Component). When I do this, the origin of the scale can be moved around to different vertices in the body, but what I want is to scale with the origin at the middle (ie so that the center of the object stays put). I cannot get this to happen.
I have both a Joint Origin and a Construction Point available which would be suitable to use as the origin for the Scale.
(ie so it would scale "around" that point). But I can't figure out how (or if it is possible) to scale around those points.
Ryan Schmidt - Autodesk Research / Design & Fabrication Group - Creator of Autodesk meshmixer
