Orientation does not change when I try to Extrude
Message 1 of 27
I'm having an issue when I am sketching in 2D and attempt to perform an Extrude, or a Press/Pull  The orientation remains fixed in the 2D orientation, (TOP, RIGHT...) instead of rotating to orthographic as in the tutorials.  I have checked every preference I can think of, and nothing is correcting this problem.
Alex
Replies (26)
Message 2 of 27
jeff_strater
This behavior is controlled by this preference on the Design tab:
If this setting is on, the view will rotate to look at the sketch when you first edit sketch mode.  When you exit the sketch (either through the Exit Sketch button, or the start of another command - it is not tied to Extrude), the view will return to the orientation it had before the sketch was started, not automatically to the Home view.  Also, this behavior will not happen if you have rotated the view away from the sketch view.
Jeff Strater
Engineering Director
Message 3 of 27
Unfortunately that setting has made no difference in the behavior.
Message 4 of 27
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Hmm, that does seem interesting. Can you please capture a Screencast of the issue and show us your preferences as well. Personally I have never seen this happen with "Auto Look at Sketch" enabled. If it is a bug, we want to make sure we capture this.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 5 of 27
Same! I have that problem and it kinda irritates me!
Message 6 of 27
lars_christensen
Try to Right-Click the view cube in the upper right corner and select perspective with ortho.
Best,
Lars
Lars Christensen
Technical Marketing
cadcamstuff.com | YouTube | Twitter | LinkedIn
Message 7 of 27
pagedm
Observer
Observer
I don't know what I did to make it stop working but the following fixed the view automatically changing between edit sketch and extrude for me:
Right-Click the view cube in the upper right corner and select "Reset Home"
Good Luck
Message 8 of 27
Auto look at sketch must be checked for you to have the workspace rotate to the face you chose when you right click on a face to create a sketch while you are in the default in the home view (showing top/front/right).  It has no bearing on a sketch returning to home view when you act on it.
If you are already viewing a face (instead of being in home view) when you create your sketch, there doesn't seem to be any way to ever get it to automatically return to home view when you do an operation like Press/Pull on it.
This setting has no bearing on changing a sketch after the fact, whether it was check or unchecked when the sketch was created.
Is there a way to get a sketch to return to the default home view if it was created while you were already in a face view?
Message 9 of 27
I tried the other suggestions and was not successful. I then clicked the house symbol next to the orientation cube and that corrected the problem for me.
Message 10 of 27
thingiverseWDWCL
Observer
Observer
The last posting is quite 9 months ago, but I'm having the same issue with my fresh installation. Following Lars' tutorials, I noticed the same behavior on my machine. The view doesn't change to isometric view when pressing 'Q'.
I double checked that "Auto look at sketch" is ticked, as well as "perspective with ortho" like recommended by Lars. Still it wouldn't change the view when finishing the sketch or pressing Q. Might be still a bug there?
I'm a newbie at Fusion, so I don't really have an idea how else I could fix this.
Message 11 of 27
thingiverseWDWCL
Observer
Observer
Strange, after 10 mins I tried it again with the same settings and this time it worked ok. Nevermind. 😁
Message 12 of 27
Knoparen
Observer
Observer
Even though it is an old thread with the last post 6 months ago, it may be more than me who are still facing the same problem.
I struggled with this problem for weeks before finding the solution.
First, make sure that "Auto look at sketch" under "Design" is checked.
Then make sure "3D Sketch" in the "Sketch Palette" is NOT checked.
Message 13 of 27
thingiverseWDWCL
Observer
Observer
Yes correct, I have the same settings. Thanks for sharing the screenshots. 👍
Message 14 of 27
I was having the exact same problem. After finishing a sketch in a 2D view I would press E to extrude and the orientation would not change back to 3D.
Message 15 of 27
@Knoparen Thank you for the guidance.  It worked for me.  What exactly does 3D sketch option do?
Message 16 of 27
jeff_strater
if this option is on, it allows you to create 3D geometry in the line and spline commands - you can sketch on planes other than the sketch plane, snap to model geometry, etc.
Jeff Strater
Message 17 of 27
Thank you for the prompt response.
Message 18 of 27
Latheboy
Hello, I realize that this is an old thread, but I have the same problem, tried all of the suggested settings and still no auto rotate to 3D when extruding. Does anyone have any other setting suggestions?
Steve
Message 19 of 27
TheCADWhisperer
@Latheboy
Here is a suggestion (question).
Message 20 of 27
Latheboy
I saved the file to an .f3d and tried to drag and drop.  Not working for some reason.  Thanks...
