Orbiting with right mouse button (Tinkercad setting) only working intermittently
men8ifr
men8ifr
As above from the preference menu I have selected
and it no longer orbits smoothly, seems as if it flickers between selecting a menu option or orbiting. It worked fine a week ago, I have changed no other options in that time.
I will add the screencast once it appears in the list (seems to take a while)
men8ifr
Screencast attached
men8ifr
jhackney1972
I noticed your Orbit indicator flickers indicating that your right mouse button is actuating intermittently.  I would swap out out mouse and make sure you do not have a hardware issue.  In my Screencast notice the Orbit indicator does not flicker during the whole session as I hold the right mouse button.  Since I cannot see your mouse action, I am assuming you are holding the right mouse button continuously during your Screencast.  Also look at the command indicator at the bottom of your Screencast and mine and notice my Orbit command is constantly on.  I am using the TinkerCAD settings.
John Hackney, Retired
