Optimize/reduce points on intersect sketch
PLAmenPRINT
PLAmenPRINT
Hi, I am trying to offset and extrude-cut an intersect sketch but Fusion crash every time I try to offset it.
I think the reason could be the multiple (needless) points on the sketch.
Tried to break the link but it crash again.
Is there a way to optimize/reduce the points?
The only option that remain is redraw.
g-andresen
try this:
1. edit sketch
2. break link
3. reduce points
4. reorganise points
günther
TrippyLighting
Please share the design file (export as .f3d and attach to next post).
jeff_strater
Going to go out on a limb here and make a guess as to your workflow.  I suspect that you imported a mesh design, then used the default mesh to BRep conversion to convert it to a BRep where each mesh triangle is a separate BRep face, then intersected that BRep with the sketch to get this projected geometry.  This is not a recommended workflow.  If my suspicions are correct, use the Create Mesh Section command, and then Fit Curves to Mesh Section command to get a better (and smoother) approximation to this geometry.
Jeff Strater
Engineering Director
PLAmenPRINT
This is exactly how I did it 🙂
Thank You very much for showing me the right, easy and most important working way.
