Open File read-only
Open File read-only
jean-michel_legoff
Open File read-only
jean-michel_legoff
Since some times, it's possible to set up Fusion to be in Read only mode to prevent any bad manipulation on a collaborator file.
But this feature is actibvable only when the file is already opened.
Could it be possible to open it in this mode directly from the Data Panel?
Many Thanks
jhackney1972
I will offer this possible solution to a Read-Only file from the Browser.  If you create a Milestone, that file version cannot be written over.  You can update it to a new version or Save As a new file but you cannot save the Milestone version.
(view in My Videos)
John Hackney, Retired
