Offsetting different edges on different axes at the same time (Geodesic Dome)
BedirhanUyar
Message 1 of 16
BedirhanUyar
First of all, good day. I'm pretty new to Fuson 360 and I made a Godesic Dome. But they only have faces. There are 160 of them, and they are all on different axes... I must first offset the edges of all the triangular faces of this dome, then extrude them, and finally chamfer them, but since their axes are different, I have to do them all one by one. I couldn't find any resources on how to do this quickly.
Accepted solutions (4)
Replies (15)
Message 2 of 16
BedirhanUyar
(The image in the second stage appeared to be of low quality)
Message 3 of 16
wes_glassmeyer
@BedirhanUyar I am new to Fusion as well, so take this as just a suggestion, but I would think to simplify your parts down to the individual triangles. I would then joint those triangles together to make hexagons. I would then joint a combination of hexagons and triangles to make the complete geodesic dome. Just an idea, hopefully it makes sense.
Message 4 of 16
davebYYPCU
In Fusion, you make one finished panel, and then using Circular Patterns duplicate them.
Might help…
Message 5 of 16
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned
to the forum for further guidance.
When I was first learning fusion I had been doing an AutoCAD project which involved a geodesic sphere. I had done a
great deal of research on geodesic structures as I had hand calculated the correct angles (to 3 decimal places) of such
a structure that could be scaled from a 5m diameter structure up to 100m. I could make it bigger than that if I went to
five decimal places. I had not had any previous experience with parametric modelling and did not understand much of
the underlying theory. I was very competent at 2d and 3d DRAWING but there is a very different mind set to the way
you do things when you 3d MODEL.
Check out this message thread.
https://forums.autodesk.com/t5/fusion-design-validate-document/advice-to-a-new-fusioner/m-p/11161063
This thread is very long, over 40 messages, and it goes into several different areas of modelling, including how to get
started. It also includes a number of ways to model geodesics and it taught me quite a lot about how fusion works on
the way.
There are several tricks to doing geodesics. Many so called geodesic calculators do not actually create a structure that
can be properly engineered and constructed. This is because those calculators create a series of triangles that actually
all touch the inside of an actual sphere. In theory that is what you want, but in practice it does not work (as I discovered).
The problem is that this kind of structure does not have standard lengths and angles. From an engineering fabrication
and assembly point of view it is a nightmare, sort of the engineering equivalent of doing a jigsaw puzzle. Buckminster
Fuller, the guy who is famous for introducing the world to geodesics in the mainstream, worked out a method that used
a slightly modified geodesic structure where all of the "legs" of each triangle were at a very specific ratio, and this created
a structure where all of the angles were the same (but had to be extremely accurate). From this work and work by others
you can engineer a fully scaleable geodesic structure simply by changing the length of the legs and maintaining the ratio
of the lengths.
I spent a great deal of time on this project as it was one of the major pieces for my engineering Diploma. The report I handed
in was about 40 pages of calculations and data to prove it would all work.
Hope this helps you.
Cheers
Andrew
Message 6 of 16
TheCADWhisperer
@BedirhanUyar
@wes_glassmeyer
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
Message 7 of 16
g-andresen
Take a look here
günther
Message 8 of 16
BedirhanUyar
As you can see in the attached f3d model, I created the geodesic dome. However, as seen in the image of the prototype model I made in blender, I want to thicken and extrude the edges of the triangular surfaces on this dome.
Message 9 of 16
jeff_strater
Is this what you want?  Just stitch and thicken:
Jeff Strater
Engineering Director
Message 10 of 16
TheCADWhisperer
@BedirhanUyar
First thing I would do is fully define your Sketch1 and then resolve all of the unresolved issues highlighted in yellow on your Timeline.
I didn't complete the patterns given the unresolved issues indicated on the Timeline...
Message 11 of 16
BedirhanUyar
Thank you, this will work for me as you showed me, but what I really want to do is to thicken only the edges, not the surfaces, and then extrude the thickened edges.
Then I will eliminate the surfaces and it will be a structure consisting only of triangular profiles.
Isn't there a quick solution for this purpose, other than selecting each triangle separately and then doing the offset inwards manually? Once this is done I will extrude all the offset edges and then chamfer them
Message 12 of 16
BedirhanUyar
I don't know exactly how to fix the yellow errors
The program crashed at some point, so maybe that's why? The error is "The project source is lost, Cache is used!" writes.
Message 13 of 16
TheCADWhisperer
@BedirhanUyar
Then start over and attach your new file here.
Offsetting the sketch lines looks like wayyy too much work to me.
Message 14 of 16
TheCADWhisperer
Did you figure out how to fix your foundation geometry by starting over?
Once the foundation is good - then we can build the frame relatively easily.
Message 15 of 16
BedirhanUyar
Yes, I went back to the timeline and made the extrusions and edge offsets I mentioned on the initial sketches. Fuson 360 automatically applied them to the final model 🙂
Message 16 of 16
TheCADWhisperer
@BedirhanUyar
Sounds to me like you did it the hard way.
