Offsetting an Offset Problem
I can't offset from an offset in a sketch. I have to, instead, offset from the original profile. For example, creating a series of concentric circles at 2mm distances I draw my source circle, then offset the second circle by 2mm but for the third circle I can't offset 2mm from the second. Instead, I have to offset the third circle 4mm from the original.
PhilProcarioJr
@Anonymous
Fusion doesn't support offsetting an offset.
You will need to make your second offset from the same geometry as the first.
Your other option is to delete the offset constraint which will turn it into normal sketch entities and allow you to offset it from the offset but you will lose the parametrics of the original offset.
Phil Procario Jr.
Owner, Laser & CNC Creations
