Offset plane from object possible?
Scoox
Message 1 of 8
Scoox
When creating an offset plane, I select the source plane and then Fusion 360 asks me to type in a distance value. But, when extruding, Fusion 360 gives me the option to extrude From Object, which is kinda neat. Is there a reason why a similar workflow is not available for Offset Planes? Am i using the wrong command? Cheers!
Replies (7)
Message 2 of 8
jeff_strater
No, there is no option like this available today.  You can feel free to propose it on the  Fusion IdeaStation.  I'm not really sure how such a command would work, to be honest.  What does "from object" mean in the context of an offset plane?  Isn't that the plane you offset from?   That's how Offset Plane works.  Or, do you really mean "to object"?  That is, be able to offset a plane so that it passes through a point or vertex?
Jeff Strater
Engineering Director
Message 3 of 8
huszak.marcell
The two workflow looks very similar to me, or it's me who don't understand the question correctly. Can you show me some printscreens? I'd like to help if I can 🙂
Student Expert
Student In Industrial Design Engineering
Message 4 of 8
Scoox
Hi guys, first and foremost, I apologise for not replying till now. Work's been extremely busy the past two weeks and I've had little free time at my disposal.
Here's what I'm trying to do (please look at picture below). I want to create a construction plane parallel to face 'A' and passing through point B.
In this particular case, I could use Plane Along Path and set the distance to 1.00, which moves the plane all the way to the end of the path, which happens to be point B. Of course, this workaround works only because the path happens to be perpendicular to face A. Assuming B was just a point in space, the only solution I can think of is to measure the distance using the Measure tool, and then use the measurement as the offset, but that's a bit too convoluted. Another rather messy workaround would be to extrude a temporary construction body using the "to object" parameter, then create the construction plane on the face of that body, and finally delete the body.
The same problem exists when using the Offset Faces tool, there's no option to offset to existing object (sorry, indeed, I meant TO object, not from).
Conversely, the Extrude tool allows extruding from and to existing features, and the Tangent Plane uses an existing plane as reference.
I hope that makes sense 🙂
Message 5 of 8
TrippyLighting
This makes perfect sense! I cannot count how often I would like a construction parallel to something through a point.
Message 6 of 8
Scoox
Good to know I  wasn't going mad
Message 7 of 8
just found an entry in IdeaStation (and I gave it a vote) - creation date: 2014 (!)
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/construction-plane-parallel-to-plane...
Message 8 of 8
Scoox
Thanks for that, I've just voted on it. Judging by the age of the thread, indeed it doesn't seem like Autodesk are in a hurry about this one.
