Offset extrusion of existing pipe component
mrdawborn
mrdawborn
I want to create a type of cover that snap fits over this existing pipe loop component. I have created the offset but not sure how I can make it semi-extruded as opposed to being a solid pipe (using the create -> pipe feature).
I've attached an example of what I want to do but would prefer the 'slit' (opening to be bigger = customizable).
How would I go about doing this? I'm thinking revolve but then I would need to create a sketch of the cross section. Is there any easier solution?
g-andresen
please share the f3d file for reply
günther
mrdawborn
Thanks for the reply. Attached.
edit: Project is a bit of a mess while I experiment with solutions. Sorry
g-andresen
1. cleaned sketch 1
2. create pipe
3. sketch cover profile
4. sweep cover profile
günther
mrdawborn
That's awesome, thank you. Yeah, sketching the cross section and then sweeping around the pipe path is exactly what I should have done.
Thanks again.
