Offset disappears when I extrude
I am doing some cross sectional areas along a length and I want to extrude the inner curved shape -56mm.  When I do so however the offset'd outer curve disappears, however I want to loft or extrude it the other way.  How do I get this offset to become visible again?
HughesTooling
Just find the sketch in the browser and click the lightbulb to toggle it's visibility.
Mark
Mark Hughes
Owner, Hughes Tooling
**** it that has been driving me mad for 6 months.....thanks!
So Q? why when you extrude does it turn the sketch off and can I stop that automatic feature somehow?
HughesTooling
Personally I try to use a sketch for only one feature so 90% of the time having the sketch auto hide is more helpful. If you are reusing sketches a lot I wonder if your workflow is good, are you following Rule #1. There have been requests on the Ideastation for some way of having sketches stay visible, if that's going to happen I'd want a checkbox on the dialog because I wouldn't find it that helpful.
Mark
Mark Hughes
