Odd pattern behavior
CruftMeister
CruftMeister
I inserted an external assembly and then unlinked it and am now seeing an odd behavior with a pattern that was fine before unlinking.  Editing the pattern doesn't seem to fix the behavior (patterned elements floating in space). I could just remake the pattern, but it seems like it might be a bug.  Has anyone seen anything similar?
Screencast shows the behavior
Thanks ..  .
SaeedHamza
No screencast is attached
Could you please also attach the file
Go to File > export > .f3d and attach it to your next post
Regards
Saeed Hamza
CruftMeister
Odd, the preview clearly showed the screencast in the body, however now when I try insert the screencast using the form button below I'm now getting the message  "Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied."  So I can't actually insert my screen cast here - gotta love whatever backend powers this forum . . .
I was however able to paste the URL to the screencast below.
https://screencast.autodesk.com/Embed/Timeline/8d2c4440-2bcb-4322-9872-af8321aab5ff
I also tried to export the f3d file but Fusion locked and then crashed. Next time I fire up Fusion I'll look into exporting again, but I'm stepping away for now, too much crashing
