Object turned into lines, object turned into a box. Help
So I was doing some drawing and I do not know what I pressed but the object is no longer visible as an object. You can see straight through the object and it is now just lines. It still says its an object but I need to have it back in the original way but I do not know how to change it back. Can someone please help because I couldn't find anything explaining what happened.
etfrench
At the bottom of the Fusion 360 window, check your Display Settings.  The Visual Style is probably set to Wireframe.
ETFrench
TheCADWhisperer
If you can't figure it out ...
This fixed it thank you.
