object not selectable in sculpt environment-it's driving me crazy.
I want to be able to sculpt, but the form I've made is transparent and I can't select it at all. I've been trying to figure this out for over a day. Please help.
HughesTooling
Did you right click the Form in the time line and select edit?
Mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
The transparent body you see is the solid body created from your sculpt body.  Is it possible that you've made the sculpt body invisible?  I'd like to see what's inside your Bodies folder:
Or, better yet, if you could share your design here, most probably someone could diagnose your issue quickly.
Jeff
Jeff Strater
Engineering Director
