Object hollow when slicing
r.voigtlaender
r.voigtlaender
I am new to Fusion 360. I try to design a replacement part. The public link is: http://a360.co/1TRWynT
My issue is that the pins shafts are hollow when I export the object as stl and slice them for 3d printing. If I run a section analysis on the object the pins seems to be filled. I don't know why this happens.
I am sure it's my fault. I just don't know what I did wrong. Any advice?
Robert
Mike.Grau
Hi Robert,
thank you @r.voigtlaender for sharing your design. I have checked your pin shaft it and it is absolutely fine, just few chamfers in the history are not referenced.
As soon as you export a solid body into an stl file only the outer suface will be outputed as triangular mesh.
The 3D Print Tool like Autodesk PrintStudio and Autodesk MeshMixer requires just a watertight hollow model which is represented by closed triangular mesh.
The tool treats the closed watertight stl mesh as solid part and creates the toolpath for this. I think this video here is very helpful to refine the surface of your stl file.
I would recommend to change the maximum edge length to a minium of 0.75 mm for your part which creates uniform mesh and captures more features.
I hope my explanation and the video helps a to understand the process.
Mike
r.voigtlaender
Thanks for checking the model. Good to know that the model is ok. Must be a
flaw with the slicer then. I solved it by adding more outer perimeters.
This forced the shaft to be filled.
Never had such a problem before.
The tip with the max edge length was great. The STL is much more detailed
now.
Again. Thanks.
Robert
Mike.Grau
Hi Robert,
I´m glad that I clould help you. Thanks again for your post in the Forum.
I hope I can help you next time as well.
Mike
