object has gone missing
gneF9AUM
gneF9AUM
I was working with an object built from dxf. I needed another layer from another drawing so I imported another dxf drawing and after I projected two parts that I needed for the drawing my object disappeared.
The sketch is stopped, but I cannot get the object back. it is there and opacity is 100%. there is only one component so not sure what I have done. see attached
thanks
davebYYPCU
your partial screen shot, gives some clues, but without the file to check,
it looks like as you say -  have stopped the sketch, then clicked on part of the Component, in the drawing window
your browser does not show any error, there is only one sketch visible, all the others are turned off.
There is a small purple blob, probably the projected article.
What "öbject" are you referring to?  Importing a dxf should not leave you with these screen colours.
