Obj Export Problem
Obj Export Problem
Obj Export Problem
Hello, I have finished my project in Fusion 360. When i want to obj export, i did brep to mesh and save as obj. But when i open that obj file in 3dsMax the project doesnt seem like my own project. What is the problem? Thank you for answering.
TheCADWhisperer
Attach the *.f3d file here.
Project is here
TrippyLighting
When you export this into a .obj it will be a  triangulated mesh. What is it you want to do with this in 3DS Max ?
You'll get better results exporting that into a .stl - also a triangulated mesh - directly from Fuoisn 360 as you have better control over the resolution.
It would look to me that the resolution of the mesh in your .obj export simply is too low.
TheCADWhisperer
I ran your file through a Quality Check in another software and found one issue.
I repaired that and exported to obj (attached).
