nVidia Driver Crash Free Form Selection Tool on SVG import
bensbenz
Message 1 of 8
bensbenz
Been working with SVG's a bunch over the past few days, I seem to be getting a repeatable driver crash when selecting parts of the SVG with the free form selection tool. I can usually select 1-2 times and then I get a pop up the nvidia driver has crashed at which point many things in fusion stop working, I have to save, close and re-launch fusion 360. I was using a month old driver, updated to the latest version and I get the same crash.
Replies (7)
Message 2 of 8
yqliu
Hi @bensbenz, there is no special thing to handle SVG in Fusion.  Are you using space mouse? If so, have you tried to select the curve not using space mouse and see if the problem happens? Did you see the same issue in other environment?
Richard
Message 3 of 8
bensbenz
I have a 3d spacenavigator but not the mouse, not sure if that's what you
mean. I have the same problem with selecting any part of a sketch with the
free selection tool, I just happen to have been working on sketches
composed mostly of svg imported items at the time.
Message 4 of 8
yqliu
I'm not 100% sure, but I think it's related to the 3d spacenavigator. We will look at it and see if we can reproduce the issue.
Richard
Message 5 of 8
Hi.
This happened to me to!
Was working on a svg file yesterday and switched to the free form selection tool and Nvidia kernel crashed when using it.
No space mouse here.
Message 6 of 8
Tried a screencast for the first time. 🙂
When using the free form tool and selecting to the left it works. But when trying to the right it crashes.
File attached.
Message 7 of 8
bensbenz
You are right (correct)! I just confirmed the exact same thing. Selecting going in the left direction works, go right and it crashes. I have even tried disconnecting my space navigator and I have the same problem.
Message 8 of 8
yqliu
Thank you @Anonymous, @bensbenz for letting us know your discovery. You are right, it's not related to space navigator. I can reproduce the issue in my side. I have logged a defect (internal ID is FUS-26749) and our development team will look at it as soon as possible.
Richard
