no user logged in
no user logged in
Message 1 of 9
no user logged in
hello
i just downloaded fusion 360. but when i installed it.it didnt not aske me for any sign in..nor i am able to save my progress
Replies (8)
Message 2 of 9
innovatenate
Autodesk Support
Autodesk Support
Can you review the below link to see if it will help with the sign in issue in Fusion 360?
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Netw...
Please let me know if you have any questions or if the article doesn't help.
Nathan Chandler
Principal Specialist
Message 3 of 9
this is all what i see..there is no netwrok preference
Message 4 of 9
Pavel_Holecek
Sorry to hear that. I hope we will fix it quickly.
I recommended you to use these steps.
Steps to get Sign-In dialog:
  1. Close Fusion 360
  2. Remove this folder : "c:\Users\<user_name>\AppData\Local\Autodesk\Web Services"
  3. Run Fusion 360
Sign-in dialog should be displayed.
Please let me know if it helped you or not.
Also I would like to ask you if you could tell us  if you have installed another Autodesk products on this PC? If yes, probably it will need Sign-in as well after this action.
Thank you a lot
Pavel Holecek
Autodesk QA team
Message 5 of 9
HI Mohammad,
I did not find the folder with 'web services' in AppData\Local\Autodesk
I'm trying to run student version with college proxy server here.
Message 6 of 9
innovatenate
Autodesk Support
Autodesk Support
The below URL's maybe helpful to triage with the school's IT department and running Fusion 360 in a proxy environment.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Inst...
Nathan Chandler
Message 7 of 9
Rich235
Hi, I have exactly this problem after update yesterday. Now I can't log-in.
It started when I loaded Fusion 360, the files/data panel on the left was blank white, so I logged out but could not log back in. I shut down and re-started, and it came back saying it had been updated but then hung. When I shut down again it came back with the normal screen but with no user logged in and no way to ask it to let me log in. I've read lots of forum replies, deleted files and I've even re-installed but no difference. I'm at home with no proxy and it has been working fine for the last 5 days with connected to the cloud and version saving. I'm able to log in to the space on the web and see my models so I know I have connectitivy to Autodesk servers, but just can't get Fusion 360 to ask me to log in. Any advice please? Thanks for your help.
Message 8 of 9
baribak
Hi RIch,
To get the login screen you need to delete the Web Services folder.
  • On Windows this is found in: c:\users\<username>\appdata\local\autodesk\
  • On the Mac it's: /users/<username>/library/application support/autodesk/
Note: On the Mac you may need to "unhide" the Library folder. On Windows, you may need to unhide the AppData folder.
Once you delete that folder Fusion should prompt you for login credentials. If it doesn't then we need to look at how you installed.
Hope this helps.
Kevin Baribault
Fusion 360 Quality Assurance
Message 9 of 9
Rich235
Hi Kevin,
Thanks for your reply. Unforuntately this did not work for me. So I've clean uninstalled and have been trying to re-install, but that is freezing on "initialising". One of your excellent guys has been helping me via chat, but I think the OS was in some way corrupted by a crash not Fusion related, and that is preventing the install for some reason. Looks like I have to start with a fresh OS and try again. From the same physical location it would start the install on another PC, so we know it is not the internet connection. Thanks, Richard.
