No shadow casted on white solid background
jacquesKWQBQ
jacquesKWQBQ
Dear community,
When I render on a light gray solid background I get nice shadows ( ground plane turned on ), but the lighter gray I go with the background colour, the lesser shadow is casted and when I go all the way to plain white, there seems to be no shadow at all any more.
The goal is to create a pack shot of a product, which has to be on a perfect white background ( or transparent ). Note that I also tried to create a white "floor" component and that will indeed cast a nice shadow, but that plane will never render as plain white. I also tried to use a non white background ( even with environnement as bg ) and then render with transparent background turned on, but then again, no shadows.
Is this expected behaviour ? What am I missing ?
jacquesKWQBQ
Did some more investigating. Here is a render with no environnement brightness using an emissive face only and "environnement" as background:
Now, same setup with "white" background:
I might have a wrong understanding of what it means to change the background ?
( btw, rendering this with transparent background gives the same result )
Can't I have a plain white background but still have the shadow rendered "as if" there was a ground plane. Isn't that the idea ?
jacquesKWQBQ
Just to make sure I wasn't having some unrealistic expectations about rendering on white background, I tried Onshape for the first time ever, and this is my first render with the default scene setup:
This is exactly what I want / need !
Even rendering with transparent background I get exactly what I was expecting: object on transparent background WITH shadows.
Is that simply not possible in F360 ?
Is this where I switch to a different CAD program, or am I indeed missing something ?
TrippyLighting
Nope, a render with transparent background AND shadows isn't possible in Fusion.
