Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Newbie Advise appreciated for drawing for drawing a simple Closing Mechanism!
3 REPLIES 3
552 Views, 3 Replies
i want to draw a Brass Pencil Case with fusion 360 and optimize the design of  it. I am new to fusion 360 and i can not figure out a thing. The Pencil Case has a simple closing mechanism.
Inside it's a little cavity, outside it's like a buldge (I attached a picture to demonstrate)
Could you please give me a little hint how this is constructed with Fusion 360?
Any help is very much appreciated!
Many thanks in advance and best regards,
3 REPLIES 3
TheCADWhisperer
TheCADWhisperer
Revolve, Fillet and Shell.
TheCADWhisperer
TheCADWhisperer
See Attached.  (Let's see if you can model the matching lid.)
I made it a bit too tight...
Advantage of parametric modeling - easy to adjust this.
in reply to: TheCADWhisperer
Wow! I cant thank you enough! Thank you so much for such an detailed reply! I will try my best!
