New to Fusion and converting the Mendel90 3d printer design to fusion
Hi
I have taken a stap at converting the Mendel90 3d printer design to Fusion360
My first obstacle is to make the 4 sheets of the frame meet up without overlapping and make edges flush
i have 4 dxf's that i now is "almost" ok so i thought it would make sense to start out with those and line up the printed parts by eyeballing then and then later correct the holes so there are 100% where they should be
for now i have just made a document and linked to the 4 sheets and extruded them to 3mm thickness like the dibond sheets will be
and i have placed all the fixing blokcs just by eyeballing it along with the stepper brackets and bar clamps for the Z axis.
my first goals are to make the sheets meet and edges are flush, there is a small note here in that near the front corners of the base sheets are are 2 small holes that need to stay in relation to the corner. same on top of the gantry sheet
then my next goal is fo have all the fixing blocks touch the sheets they are placed against
last in this round is to place the stepper brackets and bar clamps so that the smooth rod is at right angle to the base sheet no matter what angle you look at, and it should be parallel to the gantry... same on the other Z smooth rod.... and the 2 smooth rods should be parallel to each other
why i want to go through all this is to first of all share the design in a more modern format than openscad
next is to make a 2nd printer for myself that is more correct than what i have.
i tried to look up guides for align parts but it just flipped the sheets and not move them like i had planned
public link: http://a360.co/2wAtb2s
