New to Fusion 360, need help with Combine tool
forestli
Message 1 of 9
forestli
I would like to combine two solids together but one of them could not be selected by the tool. please reach out to me if you know the solution. TYSMScreenshot 2021-12-23 160130.png
Replies (8)
Message 2 of 9
jeff_strater
it looks like one of your bodies is a mesh body.  Combine only works on solid bodies.  You will have to convert the mesh body to a solid BRep in order to combine them.  You can also combine 2 mesh bodies, in the Mesh toolset, if both are meshes.
Jeff Strater
Engineering Director
Message 3 of 9
TrippyLighting
Can you share the mesh file?
You might have to zip it before attaching it to a post.
Message 4 of 9
forestli
I have gone through a tutorial on turning the mesh into a solid (tutorial link: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
it resulted in a bunch of lines covering the shape of the original mesh. is there a way for me to get like a solid in one piece?
Thank you for helping me and merry Christmas!
Message 5 of 9
forestli
Here is the file
Message 6 of 9
TrippyLighting
Converting this mesh into a BRep is not a good workflow for the reasons you describe.
Also, none of the sides is aligned with any of the origin planes.
I would completely redesign this from scratch using the native tools in Fusion 360.
Message 7 of 9
TrippyLighting
Here's a start. If you can explain what you want to do with the result, tha would help.
Message 8 of 9
forestli
I am not familiar with fusion but my ultimate goal for this is to make a case based on the existing model. What I am trying to achieve is to convert the mesh model to solid and subtract it to a bigger solid.
Message 9 of 9
TrippyLighting
@forestli wrote:
I am not familiar with fusion but my ultimate goal for this is ...
My guess is that without getting familiar with Fusion 360, your ultimate goal might just be wishful thinking.
So download the model I had attached to my post, open it with Fusion 360 and see how it was constructed.
Then, you can decide how to move forward and provide some feedback.
