New Sketch after scaling model
ruben_van_lerberghe
Message 1 of 9
ruben_van_lerberghe
Hello everybody,
After finishing the model attached, I realized the proportions were not exactly good so I used the scale tool.
3 times, non uniform around the X-axis.
In order to make the model however, I need to adapt the measurements of my initial sketches.  I don't see how I can figure out how these measurements have changed after scaling, for some parts. Also, it's impossible to work with a width of 32.053 for example, so I will need adjust the new measurements to rounded measurements.
Should I restart the model and make new sketches, having copied the scaled bodies to get close to those proportions?
Or is there an easier way out ?
Thank you so much
Ruben
Replies (8)
Message 2 of 9
TheCADWhisperer
The usual process is to dimension and otherwise fully define your dimensions - and then simply edit dimensions as needed.  (The parametric dimensions "drive" the model.)
If you run Utility>Compute All  (Ctrl B on Windows) does Fusion return any Warnings of unresolved issues?
Message 3 of 9
g-andresen
In addition to @TheCADWhisperer's suggestion to dimension the sketches, I suggest working with user parameters.
In this way, you assign the name "height" to dimensions such as d777 for a better understanding.
günther
Message 4 of 9
TrippyLighting
That works for the "hard" parts, but for anything containing a spline, it's less straight forward.
Message 5 of 9
ruben_van_lerberghe
Thanks but I don't think I understand ( this is the first model I made and already had help here on the forum)
I need to have all my sketches fully constraint but I do have dimensions ( for example the seat and back).
Now if I go back and edit those dimensions I don't have the scaled model as a guide.
Or do you mean in a new model ?
When I do 'compute all' it gives me the yellow warning, for the Surface Stitch : Reference failure / Stitch result body is invalid.
I don't get that resolved..
Message 6 of 9
ruben_van_lerberghe
Thank you,
But for a model like this one, does it make sense to build it with user parameters?  There aren't really constant measurements..
Message 7 of 9
TrippyLighting
I believe that is a bug and have tried to bring it to the developer's attention on the EE forum. I am not sure the message has been received. There are really only 2 people left who still participate regularly. @Phil.E and @jeff_strater.
Message 8 of 9
ruben_van_lerberghe
Ok thanks.
And is the conclusion on this topic that it's best to start a new model ?
And if I do, and I want the sketches to be fully constraint, how does that work for a spline. Fix every point ( also the green ones)?
Thank you
Message 9 of 9
Phil.E
Thanks for the notice @TrippyLighting .
The problem is with Stitch. The input surfaces are causing some trouble.
If you replace the stitch with a boundary fill operation it works better, but there are some more reference failures down the timeline because that necessarily creates a new body. A little more editing is required to reconnect the downstream references.
This can be logged for the stitch command. Thanks!
(ref: FUS-70496)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
