Nested Rigid Groups / Joints
jwilds1
Message 1 of 13
jwilds1
I'm a mentor for my son's FRC team and have successfully converted most of the CAD kids over to Fusion360.  I'm helping now cleaning up their Model structure and develop the team's Technical Documentation.
One issue we've run into is trying to create the nested rigid groups to demonstrate & validate the model motion.
In the attached picture, the entire upper structure moves fore/aft on some linear bearings (A+B+C).  Then, the upper arm section (B+C) pivot around an axle high up in the structure.  Finally, the gripper mechanism (C) extends/retracts.
How would I model & link these different sections together?  I first tried using Rigid Joints (a joint for Group A+B+C, a Group for B+C and a third for just C) but it pops up a message about Constraining components and it results in movement of the highest "order" (A+B+C)
Do I have to resort to actually using Joints?
Replies (12)
Message 2 of 13
TrippyLighting
Please share the model. export as .f3d or .f3z and attach it to a post.
Yes, you very likely have to use "normal" joints.
Message 3 of 13
davebYYPCU
Section A needs a Slider Joint to the Base
Section B needs a Revolve Joint to A
Section C needs a Slider Joint to Section B.
Any Rigid Grouping would not overlap into any other Section.
Might help....
Message 4 of 13
TrippyLighting
Have you looked at the design file?
Message 5 of 13
jwilds1
The file size of the .F3Z exceeds 71MB or else I would
Message 6 of 13
TrippyLighting
Are you using a paid subscription ?
In that case you can just share the public link to the design.
Make sure to enable download.
This might also work with an educational subscription..
Message 7 of 13
davebYYPCU
Wasn't supplied - just the original post so far.
@jwilds1 Share a Public Link and allow for downloading.
Might help...
Message 8 of 13
jwilds1
Message 9 of 13
TrippyLighting
Thanks! I'll look at it as soon as Autodesk has gotten their act together;-)
Message 10 of 13
TrippyLighting
I still cannot download this model.
If you want to, I can send you a PM and you can just email the file to me.
Message 11 of 13
jwilds1
I appreciate the offers of help.  I figured out a workaround by creating Selection Sets for each movement portion and just moving/rotating manually.
Message 12 of 13
TrippyLighting
The problem with such workaround is that they start failing as the designs progress 😉
Message 13 of 13
jwilds1
No disagreement there.  Thankfully the design is 95% complete, with the remainder of CAD work being capturing real-world "adjustments", aka "we forgot to model this component, let's find a spot for it and fix CAD later" 😂
Also, this is mostly for glamour screen shots for use in documentation
