I'm new to fusion 360 but have been using it for 3d printing some small designs. When the designs are based on sketches comprised primarily of circles/rectangles/squares, things go smoothly. (I'm really loving fusion 360.)
Today I've been working on an organic sun/flower shape using tsplines sketch and the experience has been frustrating.
Moving the tspline points to adjust curves to lay exactly where I want them (matching a handdrawn design on an inserted canvas) is a laggy mess. (I try to slightly adjust point, it skews across screen. I try to drop the point in place but the point is not dropped and is 'stuck' to the cursor. Right clicking to get menu and then click ok pushes the point off to the right of where you want it. etc.)
I've followed the suggestion on this thread to reduce effects and optimize performance: https://forums.autodesk.com/t5/design-validate-document/sketching-lag/td-p/6053720?nobounce but nothing changes. (Closing and restarting fusion 360 seems moderately helpful, deleting everything seems to help too, except then I have to start over.)
I've noticed that the performance drops almost instantly upon my first addition an extra point on any line segment.
Is this a bug or is there, perhaps a limitation on the number of points on a tspline that Fusion 360 can handle given?
Can performance be helped by separating one design into multiple sketches?
Does separating designs into multiple sketches cause other problems?
I have noted that even though the original organic tspline shape was drawn all in one big closed loop (with petals because sun/flower sort of pattern), when I right click a line segment between points only a portion of the entire shape highlights... also there is a warning message about "compute failed, some sketch curves cannot be converted to profile edges" but I'm having issues locating the actual location of the problem since the line segments are usually about 5-10+ inches long with anywhere from 3-10 petals drawn.
Thanks for any assistance you can offer.
