So I'm building a little gear lever but I'm not sure my design will work as I have no experience with this.
I'm using a slot pin design where the pin = 6mm and the slot = 6.50. Ideally that would be also 6 as I do not want any wiggle but from what I understand I need to have some space to have no friction.
I'm also a bit stuck on materials. what kind of aluminium would you suggest I use for this?
thanks in advance!
link to project: https://myhub.autodesk360.com/ue2aa3fab/g/shares/SH56a43QTfd62c1cd96826294b3cafe8f6e4
there will be a spring attached to the top and bottom spacers
