Need some guidance with surface design
tilakpatel531
tilakpatel531
Hi all, hope you all are safe! I am not sure this is the correct thread for my question so pardon me if I'm in the wrong place. I need some help with surface design of a part in Fusion 360 which you can see in the attachment.
I have the density of the material and the target weight. It is a molded PU foam part. I have the height and width of the part so I will need to adjust the thickness few times to get to my target weight.
The problem is the thickness is not uniform across the whole part. It is thicker at the center and tapers down at the edges. So I would like to ask how should I design the part such that I can change the thickness can be altered without affecting the rest of the part.
Any tips or tricks welcome 🙂
shahriarsifat1802164
Hi, This might be the reason for the curved shape.
Can you share your project?
Thank you
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
In addition, you can view this:
Helmet design on Fusion 360
RUET
Thank you.
tilakpatel531
Hi thanks for sharing this video. It will be quite helpful!
