Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
need some design help
9 REPLIES 9
Message 1 of 10
kisumang
559 Views, 9 Replies
hello all
i making this object but what i made design is not much pretty and smooth because lack of my skill.
i attached what i done .
if some one fine tune my object much appreciate. thanks you
9 REPLIES 9
Message 2 of 10
TheCADWhisperer
in reply to: kisumang
I see from your other posts that you are at beginner level.
This is not an appropriate project for a beginner - is this a school assignment?
But first thing I would do is turn on Capture Design History.
Given that the part has a lot of symmetry - I would move the canvas image of the object to the Origin Center Point.
Message 3 of 10
TrippyLighting
Why is the purpose of this ?
Volume manufacturing, or is I for visual representation /rendering ?
Or do you just want to 3D print it ?
Message 4 of 10
kisumang
in reply to: TrippyLighting
hi..
this is for use private purpose.
my nose always block so i want to use it expand inside my nasal space.
yes..i will 3d printing.
i can't make smooth round here 😞
Message 5 of 10
kisumang
in reply to: TheCADWhisperer
hi thanks!
i turned on design history.
Message 6 of 10
TrippyLighting
You are using the wrong tool set in my opinion. For the intended purpose it might be better to use T-Spline modeling. I'll see if I can create a screencast later how to do this.
Message 7 of 10
g-andresen
Just to think about it.
When I design something, it always happens with a view to later use.
In addition to the form, the material used inevitably also plays a role.
In this case the function forces an interdependence of material and form in a special way, i.e. form and material are connected with each other. One cannot therefore model anything without knowing how a change in shape of the material X affects the desired function.
Why am I writing this?
I have reservations about giving advice if it is evident that this can cause health problems.
günther
Message 8 of 10
laughingcreek
don't know if @TrippyLighting has made his screen cast yet, but I agree, this is probably easier using t-splines.  here's a quick attempt to illustrate.
Message 9 of 10
kisumang
in reply to: g-andresen
thanks for your comment but actually i can't understand fully because my english is not good enough to understand.
thanks anyway
Message 10 of 10
kisumang
in reply to: laughingcreek
actually i truely beginner level and even didn't study yet Sculpt part.
since i saw your video today i start to learn Sculpt.
your work truely amazing!
i really appreciate your help
thanks again
