Need new PC, Basic Requirements?? Brand??
Joey68tc
Joey68tc
My home pc is 10yrs old, time for new.  What are the basic needs pc wise??  I do some complex parts, only basic assemblies, but do FEA at times.   I am certainly not a pc expert!!!   Do want to continue with a laptop.
Recommended brands??  (Autodesk may not appreciate me asking this but....)  I use Geek Squad for any assistance.   Thnx
TP in VA
akash.nawghare
Hi Joey,
Good time to upgrade — a 10-year-old PC will struggle with today’s Fusion, especially FEA.
For complex parts, basic assemblies, and occasional simulation on a laptop, aim for this (not just minimum specs):
Component Recommendation
OS
Windows 11 64-bit
CPU
Intel Core i7/i9 or AMD Ryzen 7/9 — 8+ cores (helps FEA)
RAM
32 GB (16 GB minimum; 32 GB much better for simulation)
Storage
1 TB NVMe SSD
GPU
Dedicated NVIDIA RTX 4060+ (4 GB+ VRAM)
Screen
15–16", 1920×1080 or higher
Laptop tip: Prefer a mobile workstation or strong creator/gaming 15–16" laptop — not a thin ultrabook with integrated graphics only. FEA needs CPU + RAM; complex modeling also benefits from a dedicated GPU.
Brands that work well: Dell Precision, Lenovo ThinkPad P, HP ZBook — or RTX-equipped creator/gaming laptops if budget is tighter. Geek Squad can support any of these; specs matter more than brand.
Tell Geek Squad: “Windows 11, 32 GB RAM, 1 TB SSD, 8-core i7/Ryzen 7, NVIDIA RTX 4060 or better, 15–16 inch.”
Official reference: Fusion system requirements
Rough budget: ~$1,500–$2,200 for a solid 5+ year machine for your workflow.
If you share your budget and whether you prefer lighter vs maximum performance, we can narrow it further.
Best,
Autodesk Fusion Community
Drewpan
To be honest, any good gaming spec machine without the bells and whistles will do.
CAD will always be Processing, Memory and Graphics. Core i5/i7 or Ryzen 5/7 with
multi-cores (at least 8). No less than 32GB RAM, 64GB better. Any NVidia 5000 series
video card with at least 8-12GB RAM, a 5060 is more than adequate. Any equivalent
video card, not sure what is equivalent to 5060. I have seen machines that have these
specs for well under $2000. You don't need pretty coloured Keyboard, Rodent, RAM or
fancy case for CAD.
I WOULD however lash out on a good monitor. I have found screen real estate makes
my life so much easier. Forget fancy curved gaming rubbish and look for resolution
over speed. As in 4k is better than 2k but <5ms resolution. I personally use a Dell U4320Q
which is a 42 inch 4k monitor. It sells as an LG monitor and Apple also use the same
panel. This monitor is more than good enough for CAD but has the advantage that I can
run fusion in a largish window and still have notes, browsers or other things easily
accessible and visible while I am working. This monitor is about AUD$800 so it is not
that expensive. Buy a $20 keyboard and mouse instead of the Gaming ones and the
economics work out the same.
Also check out the recommended AutoDesk System requirements for Fusion.
Cheers
Andrew
matthewZYM62
I would second the recommendation that you want dedicated rather than integrated graphics, but I don't think you necessarily need a 4060 or better. In my experience on a recent Dell desktop, Intel integrated UHD Graphics 770 was terrible, and NVIDIA RTX 3050 6GB is good. On a different PC I still have NVIDIA GTX 960 2GB and that seems fine too.
loveforcircuits
What's your budget?
