Need help with triangles in pattern
Hi guys, I want to create a pattern where every adjacent triangle is inverted like the picture. What I'm doing in the picture is sketch two triangles, rotate one of them and do a rectangular pattern however I want the spacing to accurate. I can't be accurate with just using the pattern tool. Do you guys know of another approach I would take please?
It would be nice if we had a feature where we can rotate sketches or objects directly from the pattern tool.
Thanks for your help.
etfrench
Try this:
ETFrench
Wow that's a hell of a workaround. Thanks a lot!!
TrippyLighting
That little bit of math is really not a workaround.
You should also consider not doing the pattern in the sketch but extrude the feature and them pattern the feature. That usually yields much better performance.
