Need help with a hole...please
PMBogdan
PMBogdan
Hello. I am a beginner in Fusion and i am a beginner in this 3d modelling domain. I have to model this sniper rifle, and i have to make two holes through the body...but not just regular holes...more like "loft holes" if i can say like that. The problem is that i don't know how...I tried to model "the hole" with the Forms function...but i don't know yet how to model it to look good...and i am asking you if there are another ways to do it. Please i really need some help. Thank you!
Screenshot (4612).pngScreenshot (4613).pngScreenshot (4616).pngScreenshot (4615).pngScreenshot (4614).pngScreenshot (4617).pngScreenshot (4618).png
samuel.templeUCPAE
Hey,
Would you be able to send me the image you are using to base your model on?
Forms can be difficult for beginners so maybe using solid shape would be better. I would suggest to get the hole you need for the grip, use sketch to draw the shape of the hole, either loft or extrude to cut out the geometry, then use fillet the get the curves.
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
