need help with a custom case workflow.
Message 1 of 8
I want to build a custom case for my raspberry pi PC. I am a noob at Fusion 360.  I can get a box drawn for the dimensions of the case, however, I'm not even sure where to start to add the HDMI power source and 3.5mm audio jack. The aluminum enclosure I want to use can be found on eBay and I have already purchased it. the dimensions are 203x145x68. Thanks for the help!!!
here is a link to the box file i started also http://a360.co/2tPC6dv
Replies (7)
Message 2 of 8
SaeedHamza
There isn't really any special workflow for this
Basically you can create a box and then use some fillets on the edges, then use the shell command in order to get a hallow box
Other than that, like openings, USB plugs and power source, they can be created simply by sketching them then extrude cut
If you have a specific part that you can't achieve in Fusion please let me know, or if you want I can create a screencast of what I mentioned above for better understanding
Regards
Saeed
Saeed Hamza
Message 3 of 8
Best regards! Basically the method of working is how say @SaeedHamza in the previous comment, it would be good to see an image of your PC to help you a little more where exactly should be the USB and audio jack ports, here I attached an image I found about what I suppose you want to do.
Message 4 of 8
I already have the case, but I need to design around it. do I need to create the case in fusion first to design around it? I have attached a few more file to give a general idea of what I am trying to accomplish with the case. thanks for the help.
Message 5 of 8
SaeedHamza
Typically you should start with a canvas and then calibrate it ( scale it ) on the box, then start a sketch on the same face the canvas is to extrude cut
Watch this screencast for better understanding
Regards
Saeed
Saeed Hamza
Message 6 of 8
omg this is the best tutorial ever. you are amazing. I really hope to be this good soon. thanks for the help
Message 7 of 8
Jajajajajaja! @Anonymous You made me the day. Keep working with Fusio360 and every day you will find something new to surprise you!
Excellent explanation @SaeedHamza
Message 8 of 8
SaeedHamza
@Anonymous
Anytime my friend. You surely can, just keep on learning and practicing. Best of Luck
@Anonymous
Thank you
Saeed Hamza
