Need help to round middle section of my project.
sean_gross1229
Message 1 of 14
sean_gross1229
I am looking for help on how to round the middle section of my project. The ends I used the "revolve" function. But the revolve function does not give me the shape I want in the middle. I am looking to have the middle section match the rounded shape of the ends if that makes sense.
Replies (13)
Message 2 of 14
programming2C78B
Revolve that entire profile and just constrain it to 180*
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 14
TheCADWhisperer
@sean_gross1229
Message 4 of 14
sean_gross1229
I will attach it when I get home.
Message 5 of 14
sean_gross1229
I have attached the file you have requested.
Message 6 of 14
sean_gross1229
I attached my file as I still cannot get it to revolve. I keep getting the "it crosses the axis" error. If you could take a look and let me know what I have done wrong to not allow it to revolve in the middle that would be great.
Message 7 of 14
TheCADWhisperer
@sean_gross1229
Why did you use a Spline rather than a 3-Point arc?  (There is only about the thickness of a sheet of paper difference at the greatest difference.)
Message 8 of 14
sean_gross1229
The three point arc did not seem to give me the curve I was looking for. I may have not done it right. I have only been using fusion for about a week.
Message 9 of 14
jeff_strater
I'm not sure if this is the result you were looking for, but the key is that you need to revolve only 1/2 the profile, so you need another line in your sketch:
Jeff Strater
Engineering Director
Message 10 of 14
sean_gross1229
I tried adding a line going from the top of the one arc all the way to the top of the other arc and when I try to revolve it still selects the entire project. I cannot seem to select either half by itself.
Message 11 of 14
TheCADWhisperer
@sean_gross1229
Keep your sketches simple (in fact I could simplify this more).
And fully define your sketches...
Message 12 of 14
jhackney1972
Take a look at the timeline on this model.  You need to constrain your sketch a bit more.
John Hackney, Retired
Message 13 of 14
sean_gross1229
I got it. I started a new project and added a centerline and that worked. I guess it did not like me adding a centerline to the existing sketch I had before. Thanks for the help.
Message 14 of 14
TheCADWhisperer
@sean_gross1229
Make sure that you examine all of the techniques posted in the discussion.
