Need assistance PLEASE "Error"
zenkustumz
zenkustumz
When i apply a joint command the orientation changes and gives me and error
"Compute failed"
"Undefined error"
http://a360.co/1UySNl5
TrippyLighting
What joint ?
Looking at your file I only see a revolute joint in a ueless position but I can only assume what you want to do based on the components.
zenkustumz
Check please, front and back half should be joined and in relation to handlebar. when I apply joint the back or front changes orientation
TrippyLighting
Well, I get an error that is very suspicious. I'd like to encourace you to use the screencast tool (free download from Autodesk) record the action and then post a link to the screencast.
Otherwise I am afraid the very sparse information you provide will not gain much help.
zenkustumz
OK will do.. thanks. I was thinking that maybe my drawing path or actions were causing it.
Thank you again.
