Nastran data file to F360
I have a Nastran data file of a FEA model.  How do I import this into F360?
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to Fusion 360 community!
I'm afraid that we can't import the Nastran file directly to Fusion 360 so far.  Smiley Sad
If you want to use this function,you are able to submit your idea to the Fusion IdeaStation forum, which is constantly monitored by developers and product manager. Other forum users will have the opportunity to Vote or add Kudos to the Idea. Votes on an idea will increase the likelihood that an idea will be implemented.
Many thanks,
Ahreum.
is there another program that can convert the file into a useable format for f360?
todd_alford
Hi @Anonymous,
What is it exactly that you are trying to do.  Fusion currently isn't set up to import results from other FEA software.  You may be able to set up and re-run the analysis.  If I have a better grasp of what/why you are doing it I may be able to recommend a path for you.
Todd
Todd Alford
Sr. Learning Content Developer
shekar_sub
If you have a .NAS file then you could use Autodesk Nastran Editor (separate product that needs to be bought) to run and see the results. Thanks
shekar
