My own default material - couple bugs
I tried to adjust default material and its appearance to my own customized. I can choose it in preferences, but when I create new design I always get Warning message that my material could not be downloaded and another default is used.
So, the bug #1: Fusion claims that Steel-Satin will be used, but in the fact in my case it uses "Plastic - Glossy (Gray)" - it's the base material for my own and also default appearance for default physical material (Plastic) I set in Preferences..
After simple waiting (without rebooting/restarting anything) for about 10 minutes or so, Fusion eventually was able to "download" and apply my own default material. Therefore it was temporary effect and I'm not sure that this is an issue or I was so "lucky" to choose "right time" to change my default material.
Then I played with materials and discovered
the bug #2: When I apply (to some body) the base material of my default appearance material (or it's actually default appearance of physical material?), instead of that my customized default material is applied. And I can't apply this base material until I delete my own material from the list of used materials.
