my first project Rescue trailer
Image is the trailer that I intend to try me in making a print model in 3d. this trailer is used by the Norwegian civil defense. also another type of trailer that I intend to create model. has not it great experience using Autodesk Fusion 360 so it goes a little slowly forward over. only sketch since the image and tries to find out what I'm doing next steps
jeff_strater
Hi @Anonymous, welcome to Fusion!  This looks like a great project.  If you have any questions, please post them here, and you will find lots of support to help you.  Looking forward to seeing your model.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Her is my start pic. is not totally agree with myself on how best to make this first page. wall between the rooms I wonder to set to 1 mm. but it is possible to adjust the modules in business process. km little mistake like I want to slightly adjust on.
daniel_lyall
you can use user paramaters, you could do all the box's in one sketch and just press pull them out, then the rest of the bits can be built from that.
by useing user paramaters you can adjust everything very quickly .
with user Paramaters you can have things like wall thickness and when you demetion stuff you use the paramaters to set everything's size.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Her is first step on the left side.
daniel_lyall
what you can do is work out what the size of each squire or rectangle is going to be then if you know what the material thicknes is going to be draw it with the outside mesurement (if it's 1 mm) do a offset of 1 mm inside, that will give you outside and inside mesurment in 2 steps.
if you are unsure just ask and I will wack out a screen cast of what I mean.
there is a few way's to do what you wont.
Daniel Lyall
The Big Boss
Mach3 User
