Multiple joints on one component with Parameter
Hi
I'm just learning F360 and having trouble assembling a corner brace to a steel frame using multiple joints (see disassembled in Capture.jpg). I want to fix the corner brace to the position shown in Capture2.jpg and set this back from the front face of the frame by a variable distance (parameter equal to the thickness of a panel which will be fixed to the corner brace and sit flush with the outside of the framework).
I apply a slider joint to fit the corner of the brace into the corner of the boxing, then add a planar joint with an offset to set it back from the front face by a variable dimension  When I try this I get errors advising distance and angle conflicts.
Due to the radius, I don't think I can't simply select two points in space to handle this with a single joint, unless someone can show me how...... / is there a better way of doing this / am I just being a complete numpty!!!!
Many thanks, Laurence
chrisplyler
Only need one Rigid joint. Select your placement points carefully, and make any necessary offsets.
https://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/b8eb2...
HiChris.
It didn't occur to me to offset by the radius and then back from the face.
I was trying to find a way to reference the point where the faces would meet if there was no radius. I've just discovered construct point through three planes to place a point which is also helpful.
