Multiple edge selection for fillet?
clydeSHZ4S
clydeSHZ4S
Is there an easy way to select multiple edges for filleting? In this example, it was easy to fillet the edges running around the bottom of the cavity by using Rule Fillet and choosing the plane, but to fillet the vertical edges I have to go around and select them all individually. Is there an easier way?
k6ls
tag for more info.  I'd like to know as well.. in AutoCAD, filleting multiple entities is easy, with the M option
etfrench
The Select toolbar has quite a few different selection options.  I'd recommend experimenting with them.
ETFrench
