Multiple chamfers bending edge
jan.gladines
Message 1 of 23
jan.gladines
Say I create a box, fillet the corners and apply a chamfer to the top I get this
with a nice and smooth chamfer across the edge. However, I want the chamfer of the vertical lines to be angled differently and have a different distance. When I do this however, this is the result.
Does anyone have any idea how to fix this? I want my result to look like this edge
I really hope someone can help me out here 😕 Have a nice day!!
Replies (22)
Message 2 of 23
davebYYPCU
For the keyboard style,
create in two stages, box with fillet for the lower section, use offset plane and a new sketch for the top surface,
then Loft > Join, the higher section,
Might help....
Message 3 of 23
TrippyLighting
If whatI show in the screenshot would be acceptable, you can also simply change the fillet type from constant to chord.
Message 4 of 23
patilsm
As suggested by @davebYYPCU, you can use Loft for key board creation.
I tried and its gets display as shown below
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 23
SaeedHamza
@TrippyLighting Actually 2 fillets are better, Constant radius and Variable radius
Here is a screenshot of the result :
Regards
Saeed
Saeed Hamza
Message 6 of 23
jan.gladines
I have tried a loft but didn't get the result I wanted, care to share the .f3d file?
Also, would using a loft be a valuable option when I'm planning on sending this to a CNC?
Message 7 of 23
davebYYPCU
Not the result you want - can you give details?
To CNC - should be fine,
An interesting statement.
Message 8 of 23
SaeedHamza
@jan.gladines
Is the picture above in my previous post not the desired result?
Regards
Saeed
Saeed Hamza
Message 9 of 23
jan.gladines
Looking at the screenshot you still have the same chamfer on all four edges no? I want to have a different angled ones on the top/bottom and left/right.
Message 10 of 23
TrippyLighting
Correct!
In that case only a loft will do. If that does not work for you, then please create a screencast so we can see where that fails to produce the results you are looking for.
Message 11 of 23
SaeedHamza
Oh I see, yes this is clearly a loft with the fillets made in the sketch
Saeed Hamza
Message 12 of 23
jan.gladines
Using a loft made for a lot of imperfections. I use a 6mm fillet on the bottom part and a 3mm on the top part.Screen Shot 2017-08-21 at 13.21.02.pngScreen Shot 2017-08-21 at 13.21.08.png
Message 13 of 23
TrippyLighting
Please share your model. A normal solid loft usually does not look like that unless the twist control handles are in the wrong spot, which is some of what these screenshots suggest.
Message 14 of 23
davebYYPCU
The first pic has no fillet in the corner of the top profile.
Message 15 of 23
jan.gladines
Here you go 🙂
Message 16 of 23
SaeedHamza
This might be a bug, check these pictures below, they are for the same part, but one 1 zoomed in and the other is zoomed out
As for the transitions at the corners, they are just fine
Saeed Hamza
Message 17 of 23
TrippyLighting
@SaeedHamza @jan.gladines
There's no bug 😉
Just set your design detail control to fixed/high and these visual artifacts are gone.
Message 18 of 23
SaeedHamza
Oh I see! that's something new for me, does this command remove all kinds of visual issues like this one?
And what good is it for?
Saeed Hamza
Message 19 of 23
SaeedHamza
@TrippyLighting
That means there is nothing wrong with the model, did you check it?
Saeed Hamza
Message 20 of 23
TrippyLighting
@SaeedHamza it removes tessellation artifacts. Fusion 360's LOD (level of detail) algorithm dynamically determines how fine to triangulter objects for viewing in the viewport.
Thats' the adaptive setting in that dialogue. However, for rendering one often needs to override this in oder to remove visible faceting. Particularly for objects with high aspect ratio e.g long and thin, or for shots with short focal length.
The design is fine and the twist control hande is where it should be.
