Multi-touch festures not working in new update
 Hey,
since I updated to the last version the multitouch gestures on my mac laptop are not working anymore. They used to work like what is described on the bottom of this page: http://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/Fusion-G...
Is it a setting I have to turn on somewhere or did they just remove this feature in the new update?
Bergur
keqingsong
Can you make sure gesture-based view navigation is checked?
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
kinsleymark
I have the same issue as well (and have had it for the past few releases). What I've found is this:
When I open Fusion360 - I cannot click or do ANYTHING else on my mac until it is fully open. (This is very frustrating because F360 takes a looong time to load). If I get impatient and click a website or try and do anything else, the muti-touch features do not work. However, If I leave F360 alone (and get up and grab a coffee), the multi-touch features will work.
I'm not sure if that's what you are experiencing as well, but just a tip.
kinsleymark's solution did it, but this is definitely a bug that developers should look into...
Gesture-based navigation was already checked btw.
Thanks for the tip!
TWC-Richard
That worked for me too – many thanks – I'm very much happier now!
Worked like a charm for me, thanks! Guess getting up now and then isn't so bad after all 😉
