multi-color mesh
multi-color mesh
wout.vanden.bossche
multi-color mesh
wout.vanden.bossche
i have made a model in wich diffrent surfaces have different colors.thruster color.png
thruster.pngbut, as you can see, once i convert the single body to a mesh using a base feature, all the colors dissapear. i converted it to a mesh on order to be able to export it as an obj. i need the .obj with the .mtl with colors for a unity game. i cant export as stl either, becuase that does not support colors in the first place.g
TrippyLighting
While the .obj format supports this, Fusion 360 unfortunately does not.
