Have a project (not completely sure that's the right term...) with multiple components. The components are basically sheets of material with slightly different outlines. I want to place those outlines side by side in another file so they can be cut from a larger sheet. Looking at the existing design I don't find sketches that match the outlines - I think I must have extruded to the side to get the overall size as the interior shape (a cutout) is key and the outside just had to be big enough to include the shape and fasteners to hold the sheets together. Wondering the best way to proceed. I think I could project a sketch for the overall outline of each component within the component which seems like it would be useful going forward. Then copy the sketch. Or I could copy the component and make any sketches needed in the larger plate file. CAM of the larger plate would be water jet to rough cut the outline of the plates plus the interior cutout and fastener holes. The plates will then have some final milling - fastener head recesses, etc.
Second question is if I make a new main model what things could I do differently to make this easier?
